Old 01-23-2010, 09:11 PM
GMracer's Avatar
GMracer GMracer is offline
Default Single shear for steering rack?
Here is a CAD drawing I'm working on, basically the upper tabs will be were the rack will mount to. Two 5/8" bolts going into the rack, the material will be 3/16" and have a second circle piece 3/16" So a total of 3/8" of steel the rack will be bolted against. I could work a double shear into it, but this I feel is substantial enough and is a cleaner approach. Just looking for you guys opinion.
This is the rack I'm using, stock silverado rack. for the record.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 01-24-2010, 10:37 AM
Blake Foster's Avatar
the factory mounted them in single shear......... i guess you could build a bracket to stabalize the front and make it double shear.
Blake Foster
www.speedtechperformance.com
Old 01-24-2010, 12:29 PM
GMracer's Avatar
yea, that's why I didn't see it an issue. I still don't feel it will be, but I may build a bolt in k member to connect front and crossmembers, that would integrate the LCA bolts.
Nick Schiffer
Special Thanks to:
Old 01-24-2010, 06:59 PM
B_Alley B_Alley is offline
You should be good- a typical Grade 8 - 5/8" Bolt can take over 8500 lbs in single shear, and you've got to of them. I could run through the math and tell you how high a safety factor that is, but I'm too busy watching the game!
Bobby Alley
Old 01-24-2010, 08:09 PM
GMracer's Avatar
Cool, I plan on running Hi Strength stainless 5/8" anyway. With the doubled up 3/16" I didn't for see a problem, but thanks for the feedback.
Nick Schiffer
Special Thanks to:
