Old 02-04-2010, 01:01 PM
sacarguy sacarguy is offline
Default Smallest power steering box
Wich of the available power steering boxes is the smallest..
my car currently has the standard base 307 v-8 steering box and even headers made for power steering are having trouble clearing in my car
the engine is a 454 with afr 305 cylinder heads. does anyone have any experiance with a similar setup using power steering and a set of headers that fit ?
Old 02-04-2010, 01:30 PM
Default Ps
Well from my research i found that hte 605 saginaw was the smallest box gm installed in ps cars..
but what application i have to order for to get it and put it in my 69 is my next question or does anyone else know of a smaller gm box then the saginaw 605
Old 02-05-2010, 12:35 PM
Denvervet's Avatar
Denvervet Denvervet is offline
I have the 600 series box from Lee mfg. and just mocked up my BBC and had plenty of room for my headers.Greater then 1 " clearance......granted they are Lemons headers but still was suprised. Similar box from DSE
68 camaro, 572, tko
Old 02-05-2010, 04:48 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What they said.
Old 02-06-2010, 01:19 PM
well i found out what to do if you dont want to spend 600 bucks on a box ..
a1 cordova reman box part number 27-6531 from orilies for a 83 fbody v-6 605 saginaw .. use a manual rag joint and manual arm and it gives a ton more clearance then the stock saginaw 800 box.
total cost about 230 bucks
The wheel ends up at about 3.5-4 turns lock to lock.
Now this is NOT the hot setup for a road race car but it drives perfectly and works just fine for me since im not about taking corners fast in my 69.
Old 02-12-2010, 05:07 PM
MarkM66's Avatar
How's the feel with that box? Is it really easy to turn, or does it have a good feel to it?
Did you have to use adaptor fittings for the line hook ups?
Old 02-18-2010, 12:34 PM
it feels decent but its no road roace box ..its 15-1 ratio it also requires that you use a manual rag joint and manual arm.
its smaller in all dimensions then the stock box but has a bulge at the are it ataches to thecouple so some headers might be tight there
Old 02-18-2010, 01:22 PM
MarkM66's Avatar
I did a search on Rockauto for the year/model, they list the part number you have, and another aplication with a "performance suspension." I wonder if that box has a better feel to it.
