Old 02-13-2010, 07:48 AM
thedude327 thedude327 is offline
Default LS engine and THM400 trans?
Just wondering if anyone has used this setup? What parts or adapters are required to make it work?
Thanks for any info
Paul
1973 Z28 Street-touring project.........
Old 02-13-2010, 07:57 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
I have this setup in my racecar. All you need is the LS/Turbo flex plate made by TCI
Autokraft
Old 02-13-2010, 08:56 AM
T_Raven's Avatar
T_Raven T_Raven is offline
I know the 6.0 with a 4L80E has a spacer between the flex plate and crank. I'm pretty sure using that spacer and flex plate will work. The bolt holes for the torque converter may be slightly off but some guys have oblonged those holes when putting 4L80Es in place of the 4L60Es in the newer GM trucks.
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 02-13-2010, 09:36 AM
COYBILT's Avatar
COYBILT COYBILT is offline
this spacer depends on the year of engine you have. My 99Lq4 didn't have a spacer the crank flange was just longer.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 02-13-2010, 10:54 AM
JUSTANOVA JUSTANOVA is offline
advance adapters also makes a kit with a re-drilled ls flywheel for the th400 tourque converter and a spacer for the crank.
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 02-14-2010, 08:11 AM
Went looking for some weight info and found:
sbc iron approx. 575lbs.
ls engine alum. approx 416lbs.
thm400 trans. approx 135 lbs.
So it looks like using the ls/thm400 combo the weight comes in around 551lbs. and you keep your stock speedo drive and driveshaft length. Plus ls motors can be run to to 6500 rpm w/no drama. Aside from the tci flexplate and maybe a crank spacer, do the LS adapter engine mounts allow for a close to stock engine mounting location? It also looks like a rear sump oil pan may be needed, but other than that. Not too bad of a swap now that there is a distributor kit available for the LS engine and carb style manifolds are available.
Paul
Old 02-16-2010, 12:27 AM
CreepinDeth's Avatar
CreepinDeth CreepinDeth is offline
Looks about right. Mind you that's the all aluminum LS block.
Not the truck LS based Iron blocks.
