Old 11-26-2005, 07:56 AM
jannes_z-28's Avatar
Default First trial fit of the LS1
Just did the first trial fit of my new engine today. Just to see where everything would go. There will be some fiddeling with the enginemounts to have it in the right position.
Jan
Edit: There seems to be some trouble with the hosting server today were I have my ProToouring.se site, if you doesn't see any image look back soon again.
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 11-26-2005, 10:22 AM
907rs's Avatar
907rs 907rs is offline
, Jan! Do you have any mods planned for the motor?
Bill
Old 11-26-2005, 10:37 AM
hotwheels's Avatar
hotwheels hotwheels is offline
looks good man, nice job
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 11-26-2005, 11:39 AM
Not yet, primary goal now is to get everything in place and running. I want to drive it next summer. It will of course get headers so a matching cam for that might be put in, we'll see.
Jan
Jan Suhr
Stockholm, Sweden
Old 11-26-2005, 12:06 PM
protour's Avatar
protour protour is offline
My word for warning... If your on a budget. Get the engine running in stock form first. Then mod it. If you mod first and you have no clue if the engine ever did run. You'll be using your precious money on fixing it.
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 11-26-2005, 05:42 PM
Rybar's Avatar
Rybar Rybar is offline
Looks good Jan!
It looks like you already have an U/D pulley on there, and how is your clearance on your brake booster with the coil packs installed? I had to change my booster because it was hitting there.
I'd swap in a cam and valve springs, it's pretty easy when you have the access to the motor like that. It should still run on a stock tune, it just wouldn't be ideal.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-26-2005, 06:20 PM
67Sally's Avatar
67Sally 67Sally is offline
Looks good Jan.
W.
William Rouleau
Project PonySnake
Old 11-26-2005, 09:02 PM
awr68's Avatar
awr68 awr68 is offline
Looks great, a big step in the right direction!!
I'm feeling a bit left behind with my ProCharged LT1!!
Tony
'68 Camaro
Old 12-08-2005, 07:40 PM
Datsbad's Avatar
Datsbad Datsbad is offline
trust me , just do a cam and valve springs now . It will save you alot of time later
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 12-09-2005, 05:21 AM
Payton King's Avatar
Default good job
I see you are moving right along. Are you building your own headers or getting the ones for Street and Performance? I heard that Stainless works is making a long tube for the LS1 that can be used for your application. They were only making them for the BRP/Yearone swap.
I believe that Tyler (ATS)is making a set as well.
Do you have the clearance to run the alternator in the stock location or does it hit the frame?
