Old 03-03-2010, 06:53 PM
itsals1 itsals1 is offline
Default Will They Fit?
I have a 67' camaro, stock,drums all 4 corners.Will a 17 x 8 wheel fit front and rear with a 4.5" back spacing? What size tires would fit best if they will work,also I would like to cut down the front springs and add 2" lowering blocks.Thank you.
Travis
Old 03-03-2010, 07:47 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Travis, that should work fine.
My LS7 69 Camaro
Old 03-04-2010, 05:21 AM
Thanks Scott, Kurt also said they should work, I'm sure they will, just a little nervous because I found them on craigslist.No Retuns!
Travis
