Old 03-07-2010, 02:01 PM
R0LLDAMTIDE R0LLDAMTIDE is offline
Default bodywork on my 68
hey guys, i am looking for a little help. i have my car sanded all down and so now it is a multicolored/bare metal/bondo.... i want to prime it so i can see better just what im working with.is this a misstep or should i do it? im not a painter [as im sure you all know by this message] and i know that most if not all of this primer will be sanded off.also, i hear guys talking about filler primer, epoxy primer,etc.... what do i need?
Old 03-07-2010, 04:10 PM
NsaneHotrodz's Avatar
NsaneHotrodz NsaneHotrodz is offline
you should seal the bare metal in epoxy primer. then if you want instead of doing the filler work on that, you could spray some polyester primer over that. block it out and see what you need.
www.nsanehotrodz.com
Dewayne Morgan
[email protected]
Old 03-07-2010, 04:40 PM
do you mean just spot prime the bare metal places with the epoxy or go on and shoot the whole car? if im following you right, all my blocking should be done on polyester primer...right?
Old 03-07-2010, 06:22 PM
sorry I thought it was all bare metal. I would just spray the whole car with a good polyester primer, and start blocking.
Dewayne Morgan
[email protected]
Old 03-07-2010, 06:39 PM
is the polyester primer preferred b/c it sands good or what other factors may there be?
Old 03-07-2010, 07:55 PM
I like to use featherfill on most of my cars. Polyester primers are high build, and most of them sand easy. Keep in mind that just because it says high build that doesn't mean it will fill a dent. After you prime make sure you use a guide coat to show the low and high spots. While you are sanding don't press down hard, you do not want to distort the metal while you sand.
Dewayne Morgan
[email protected]
Old 03-08-2010, 05:14 PM
thanks man, im kinda on the right track i guess. what do you use for the guide coat?
Old 03-08-2010, 05:33 PM
I like the 3M dry guide coat.
Dewayne Morgan
[email protected]
Old 03-12-2010, 04:35 AM
GPR's Avatar
GPR GPR is offline
I epoxy prime first than use Slick Sand polyester primer to block it out followed by epoxy or urethane primer. I use old left over paint reduced a lot for a guide coat.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 03-12-2010, 05:11 PM
Thats alot of material on top of the old paint.
Dewayne Morgan
[email protected]
