Old 03-09-2010, 06:50 PM
FETorino's Avatar
FETorino FETorino is offline
Default Battery choice
What is everybody running for a battery? Optima seems like an obvious choice but which one? It will be trunk mounted and there are billet cradles for all the styles. Any reason to choose one over the other? group 34, 25/75 ect?
Rob in SoCal
Old 03-09-2010, 08:35 PM
6D9 6D9 is offline
Im running a Sears Diehard Platium sealed battery. Its a group 34. Has 880 CCA at 0 deg. Works killer so far.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 03-10-2010, 04:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Yeah, normal lead acid has served pretty well over the years. So I stick with those.
Old 03-10-2010, 08:13 AM
For situations where space is tight and packaging is critical:
http://www.braillebattery.com/
http://www.odysseybatteries.net/odyssey_battery.html (see the PC680)
I plan to use one of these for my project since I have no space.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 03-10-2010, 09:10 AM
buickfunnycar.com's Avatar
I love my GM professional series battery,cannot kill it and it spins over my 11:1 motor no problem.
www.buickfunnycar.com
Old 03-10-2010, 01:12 PM
prine68 prine68 is offline
I just went through the whole thing, researching all the different brands out there. I ended up going with the Odyssey PC1200MJT, and then the JEGS brand aluminum mount for it. All the posts I read between Pro-touring.com, Team Camaro, and here they were all good. I wanted an OPTIMA but it was like 50/50 out there for people with good things to say about OPTIMA.
Old 03-10-2010, 01:17 PM
SLO_Z28 SLO_Z28 is offline
Originally Posted by Garage Dog 65 View Post
I second that one! Those batteries are the best out there bar none.
Old 03-10-2010, 01:32 PM
JKnight JKnight is offline
I love that Optima supports our genre of cars, but I would recommend buying a battery tender to go along with your optima if you go that direction.
Old 03-10-2010, 02:35 PM
I would recommend a battery tender to anyone with an occasional use car such as these,regardless of battery make...
Old 03-10-2010, 02:45 PM
Very true, but it seems to be particularly necessary with the Optimas.
