Old 03-11-2010, 01:12 PM
AALynch AALynch is offline
Default LED Turn Signal Indicators?
I've got a Covan's dash in my Camaro, and tried using these little single LED lights I found for cheap off some little website, but I've burned through 2 and am getting tired of pulling the dash.
Are there any recommendations for lights to use for my TS indicators, bright light, CEL, and parking brake indicator? I thought I remembered seeing a little 3-light LED set-up with a small chrome ring on summit sometime, but can't find ANYTHING now.
-Adam
1969 Camaro LS1/T56
Old 03-11-2010, 01:14 PM
jy211's Avatar
jy211 jy211 is offline
are you wiring up directly or through a capacitor of some type?
Old 03-12-2010, 08:08 AM
130fe 130fe is offline
Thumbs up
Which ones are you using right now? I bought some at my local radio shack for a couple of bucks each. They sell red, green and amber ones in 3 or 5 mm sizes ( I used the 3mm ones). Something like this one; http://www.radioshack.com/product/in...ductId=2062548 They have other styles. If you want a blue one, you have to use another vender (I bought mine through DSE). I wonder how they are "blowing", is all of the wiring good?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-12-2010, 08:48 AM
Smitty67 Smitty67 is offline
Here is something I'm going to consider.
http://www.newvintageusa.com/panels.html
Dave
Old 03-31-2010, 08:03 PM
All of the wiring is new when I swapped the motor/instrument cluster, so it SHOULD be good. My dad, a huge help/source with the car, said to order the ones I want, and he'll test the resistance(I think) and figure out what resistor to put in-line to stop the problem.
I tried to just order the DSE ones, but their website doesn't work. I'll probably be giving them a call tomorrow.
-Adam
1969 Camaro LS1/T56
Old 04-02-2010, 07:52 PM
70rs's Avatar
70rs 70rs is offline
Dave
X2!! Very nice stuff.
Eric
Old 04-08-2010, 03:49 AM
IndyNova's Avatar
IndyNova IndyNova is offline
you need to run them through a resistor, probably getting too much voltage causing them to blow. They are designed to work on low voltage.
Old 04-29-2010, 04:30 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Heres a pic of the way we do them:
Clean and professional installation
Mark
Old 05-23-2010, 06:59 AM
Jim Nilsen's Avatar
Jim Nilsen Jim Nilsen is offline
Painless has blue leds and they come with the resistor in the body of them, they are a bit pricey but they look good and directly wire in with no problems.
May the Horsepower Be With You !!!!
Old 06-10-2010, 09:21 PM
BillyBobL71's Avatar
BillyBobL71 BillyBobL71 is offline
Mark
Mark,
Those look cool. Can you tell me what the lights are besides the L,R, High Beams please?
Thanks,
Bill
