Old 03-19-2010, 09:11 AM
chevelle 66 chevelle 66 is offline
Default Heidts tall 2" drop spindle for chevelle
Hello does anyone now if i can use stock upper controle arm to these spindles
Old 03-19-2010, 10:52 AM
66LS7's Avatar
66LS7 66LS7 is offline
Hi Chevelle 66, I am assuming that you are talking about a 66 Chevelle. The answer is yes you can, & later if you would like you can upgrade to there tubular control arms as well. Let me know if you need any help with purchasing.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
Old 03-19-2010, 01:30 PM
Apogee Apogee is offline
How do you avoid binding the upper ball joint with factory upper control arms at the limits of the suspension travel in bump?
Tobin
KORE3
www.kore3.com
Old 03-19-2010, 03:40 PM
66LS7's Avatar
Tobin
KORE3
Hi Tobin, you will run out of shock travel before you bind the ball joint.
[email protected]
1-262-347-9741
Old 03-19-2010, 04:19 PM
Holy wrong info batman.
A tall spindle will put any factory upper control arm on an A body into bind at static ride height.
Get SPC uppers from Marcus @ SC&C if you plan on using a tall spindle, or ones from Blake at Speedtech. Using a factory upper A arm on a tall spindle is a big no-no. Ask me how I know this...
Go ahead. I'll wait.
Tyler
Old 03-19-2010, 05:35 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Tyler
Ill bite what the deal with it
Old 03-20-2010, 05:28 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
you can't run a tall spindle with stock arms (yes, yes I know some have done it) but the upper ball joint mounting angle is drastically changed with a tall spindle putting the upper ball joint in bind under compression
www.pro-touringf-body.com
