Old 12-03-2005, 08:44 PM
Supercharged 86 Supercharged 86 is offline
Default 406
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Never run complete intake-to-pan Chevy 406
511 block casting
4-bolt block
SFI flywheel
ARP bolts
Moroso 7 quart pan
-Scrapper, trap doors, welded pickup, etc
Double roller timing chain
Comp Cams solid flat tappet cam
-.540 lift intake/.558 lift exhaust (Part # - 12-679-5)
Comp Magnum lifters
Proform 1.5:1 roller rockers
215 Dart angle plug Iron Eagles milled to 49cc
Cast crank
H-beam rods
Flat top pistons
Victor Jr. intake recently sandblasted
-Matched to 1206 gasket along with the heads
12.5:1 compression ratio
This engine has never been in a car. It should easily make 550HP.
It doesn’t include an ignition, carburetor or the carb spacer. The valve covers will be used stamped chrome in place of the current ones that say Edelbrock. I have a good size package of information and receipts that will be included. Pick up in South Jersey would be great, but not necessary.
I need to sell this as soon as possible. Make an offer.
