Old 12-04-2005, 08:54 PM
almcbri's Avatar
almcbri almcbri is offline
Default Gas Tank question-Fuel Injection.
Well I have been considering modifying a stock new tank to work with a fuel injection style engine. I am running a fuel injected TBI 5.7L 350. 325-350HP
Can I take a stock tank and replace it with this style of fuel pump and be ready to go?
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
Will I need anything else? Any type of special venting added to the tank?
Thanks for any feedback, I am having a tough time figuring out what exactly I need to do.
Old 12-04-2005, 09:24 PM
ilovefirstgens's Avatar
ilovefirstgens ilovefirstgens is offline
i happen to have that exact kit waiting to go in my tank and if you can wait a week or two ill have some feedback for you. also could just be me but their packing sucked and a couple bolts got lost...
Brian
'68 camaro
Old 12-07-2005, 03:20 PM
MaxHarvard's Avatar
Shouldnt this be moved to the fuel section
Old 12-07-2005, 03:53 PM
Derek69SS's Avatar
I was looking at that kit too. I'll be watching this topic closely
Old 12-07-2005, 04:52 PM
almcbri's Avatar
I don't know why I put this here. I guess due to the electrical.
Brian,
I can't wait to hear some feedback from you.
I called Tanks Inc. Today. Turns out their pumps are adjustable up to 10.5" So it will fit many applications. Thought that was a cool feature.
Old 12-07-2005, 07:26 PM
907rs's Avatar
907rs 907rs is offline
It should work for your application Andrew, but that baffle isn't very tall.
Bill
Old 12-08-2005, 06:20 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
TBI as in Throttle BODY Injection, or Tuned Port Injection? The reason I ask is the TBI only requires about 9 PSI to run even if you are pushing 350 hp. The TPI will require 30-45 PSI.
If you are going TBI I would think this pump is overkill because you will have to put a major regulator on it that will cause excessive heat and build up of pressure against the pump.
If you are TBI you would save a lot of time and trouble by getting a simple in-line pump and mount it on the rear frame rail.
Old 12-09-2005, 11:18 AM
almcbri's Avatar
thanks for the reply
I think you might be right as that is a bit much of overkill. I am running a TBI-Throttle Body Injection. I bought the engine out of a 93 caddilac 5.7L 350 with 10K miles. I payed 350.00 for the whole set-up so I couldn't pass it up.
I hear many guys say TBI is junk, but I think it is reliable and not a bad set-up.
I wonder if the cars and trucks that ran a TBI had pumps in the tank or on the outside? Might be a good choice to just buy a stock pump for the set-up and go from there.
Old 12-09-2005, 11:30 AM
907rs's Avatar
I know the early versions did.
Bill
Old 12-12-2005, 11:51 AM
Derek69SS's Avatar
I've parted out a '92 and a 93 caprice with TBI 305s and both had in-tank pumps.
