Old 04-13-2010, 08:49 PM
Steve67RS/SS Steve67RS/SS is offline
Default Lowering Springs
I have just put some lowering springs on the front of my 67. It has a big block, not sure if this will help in my question.
But it is still not as low as I would like it, actually I think it's a little higher.
do you know if they tend to "settle", if so, how much driving does it usually take and how much do they tend to "settle"
Or do I cut them now?
Thanks for any info. you may have.
Old 04-15-2010, 12:54 PM
Hotchkis Hotchkis is offline
senior member
Were your previous springs worn out? New "lowered" springs will often be higher than worn originals.
Most springs settle within the first 5 miles of driving.
If the height seems very off, make sure the spring is properly seated.
Old 04-15-2010, 12:57 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Agreed they are almost alway higher just drive it and make sure you put the sprigs in the pocket properly there is a stop where the end of the coil should be sitting next to.
Old 04-15-2010, 01:48 PM
jy211's Avatar
jy211 jy211 is offline
they will settle with time and driving. have you had the car aligned yet as well?
