Old 04-17-2010, 01:14 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default Aeromotive A1000 question
I just ordered a aeromotive 20 gallon stealth fuel cell with the a1000 in the cell. I'm running a street setup carb'd BBC that is 600/600. I'm curious if I can run the pump minus a voltage controller aeromotive #16306. It's not a drag car and typically goes for extended drives.
Thanks in advance
Old 04-17-2010, 04:14 PM
wedged wedged is offline
You might want to read this : info.
And this : My failed Aeromotive pump
Unless you get them upgraded for alchohol use, I wouldn't run one with pump gas.
there's even more : here
Old 04-17-2010, 04:25 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I'm no expert and really can't tell you the benefits of using the voltage regulator or the negatives of not using it. What I can say is, before selling my BBC to install my LS, I ran an A1000 with no voltage regulator on a carbed 509 c.i. motor with nearly the same hp/tq numbers as you with no problems. None at all and put about 2k on the motor with the A1000 in 2 years without a single problem. I plan on using it in with my LS swap too. So, I would say yes thru the process of elimination. But again, I'm nobody. I'm just sharing my personal experience and hope this helps.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-17-2010, 05:08 PM
Thanks in advance
Tha's way over kill for that engine. I'd run a pump controller if it was me. I NEVER have any luck with taking chances.
Old 04-17-2010, 05:22 PM
akrapovic's Avatar
Thanks for the info guys. I'm trying to buy once for a change. I ran a billet holley hp 150(which turned out to be a 125......don't get me started.) The holley took a dump..... My plan is to install a relatively small procharger this winter. I figure I'll run an over kill pump so i don't have to upgrade the fuel system again this winter.
Old 04-17-2010, 05:52 PM
That makes perfect sense. I'd still run the controller.
Old 04-17-2010, 08:02 PM
akrapovic's Avatar
You are right Todd. Relatively speaking it's the nickel and dime stuff that I always hym and haw over.
Old 04-17-2010, 08:04 PM
I quit doing that a while ago. Seriously though, you will feel better when you get out in the middle of nowhere knowing you did it the right way.
Old 04-17-2010, 10:36 PM
A good article discussing Aeromotive Fuel Pump Controllers.... it is only the one version and they make a couple - but the "reasoning" behind their use is what the article does a good job explaining.... MAINLY fuel heating up...
http://turbohightechperformance.auto...ler/index.html
