Old 12-05-2005, 06:42 PM
ArisESQ ArisESQ is offline
Cool f-body lean problem
so i replied in that "nagging questions" thread, but i didnt really wanna take over with hundreds upon thousands of questions about why my camaro leans to the driver side... but does anybody know any reasons/how to fix it?
i just had a whole lot of body work done to the car, and i had hoped that it would fix the problem, due to possibly mis-alligned body panels, but it actually just made it slightly more noticable... the car sits about an inch to an inch and a half higher on the passenger side. im planning on heading over to a body shop to see if tey can put my car on a frame machine and see whats going on.
anyone else have this problem, or any ideas how to fix it?
and just for the hey, heres a pic of my car, and a proper introduction. my names aris gregorian, and this is my car.
Old 12-05-2005, 07:39 PM
importkiller69ss's Avatar
importkiller69ss importkiller69ss is offline
Default leaning
might need to get the leaf springs rearched...under alot of power or in an accident they can flatten out...this happened to me with my original ones anf it threw the way the car sat off horribly
Old 12-05-2005, 07:41 PM
Default leaning
my car also leaned to that side i heard first gens are bad about this
Old 12-05-2005, 07:45 PM
XcYZ's Avatar
XcYZ XcYZ is offline
One of the springs lost its rate, just have to figure out which.
Cool picture of your 67.
My LS7 69 Camaro
Old 12-05-2005, 09:18 PM
thanks a lot for your replies, i really appreciate all the help . at least gave me a place to start looking at what the problem could be.
if it makes a difference, i have QA1 coilovers, and the side thats sitting HIGHER is actually set to the very lowest point it could possibly be... could this still be due to a lost spring rate, or could it be a possibly bent front clip? any othe rhelp would be great. hope your all havinga great night.
Old 12-05-2005, 09:44 PM
David Pozzi's Avatar
Make sure your subframe mounts and sub mount areas are all in good condition. I've heard many reports of lean fixed by replacing old rubber mounts.
A problem with an antiroll bar can do it too, so disconnect one end link of each bar to disable it.
If the car still leans, jack up one end but use a narrow block of wood on the jack and put it on the exact center of the differential or front subframe, run the block parallel to the centerline of the car and on the centerline. Jack that end up until the tires are off the floor then measure for level. When you raise one end like this the other end will control the car's level. Do each end of the car and see if you find one end that is causing the problem.
David
http://www.PozziRacing.com
Old 12-06-2005, 02:18 PM
i have poly urethane body and subframe mounting bushings, so i doubt thats the problem... but ill definently try removing the sway bar. thanks a lot!
Old 12-06-2005, 03:01 PM
TravisB TravisB is offline
Default ?
were they on it when you got it? If not was it like that before you put coil overs on it? this may be a dumb question but were the springs the same(hieght,rate)?
Kenny Davis Hot Rods
Old 12-06-2005, 07:48 PM
no, i replaced the original suspension with the global west arms, and the qa1 coilovers... and i dont think the car sat crooked at all at first. and im PRETTY sure that the springs are the same height and rate... but again thats something i should probably check up on. thanks
Old 12-06-2005, 08:59 PM
Y-TRY Y-TRY is offline
My '68 has the same problem, always has. Before and after all new suspension and bushings. I suspect it's a problem in the subframe of mine and the body panels were built on top of it (thus, they all look even). I've also posted this question on a couple places and it seems to be a mystery with many 1st gen owners.
Sweet car, BTW. White smoke, white car... a match made in heaven. Now get a couple turbos and you can do that at 70mph!
