Old 04-28-2010, 08:18 PM
jajunia1 jajunia1 is offline
Default just bought some Z06 wheels for my 68!!
like the title says guys i just bought those wheels for 68 camaro but they dont fit... i knew that i am going to need to modify the wheel wells but i dont know what??? so question can anyone tell me what i need to do to get these wheels to fit on my 68 camaro please! thanks in advance. im also new to this pro touring scene LOL
Old 04-28-2010, 09:32 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
You need a mini tub in the rear, dont you?
Old 04-28-2010, 09:48 PM
jcal87's Avatar
jcal87 jcal87 is offline
I think there is quite a bit of modification to fit these wheels
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 04-28-2010, 11:19 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Im pretty sure rear tubs and spacer for front and rear. But i could be wrong.
Old 04-29-2010, 08:21 AM
Apogee Apogee is offline
First question, are they C5 Z06 or C6 Z06? Originals or reproductions? The size and offset should be stamped/cast into the wheel mounting pad, so if you post up that information, that would help others help you.
Since all C5 and C6 wheels are medium to high-offset wheels, you'll need wheel adapters front and rear no matter what and probably mini-tubs in the rear like the earlier posts have said. If you have C6 Z06 wheels, a new subframe up front built for wider wheels/tires will be needed unless you're okay having the turning radius of a semi.
Tobin
KORE3
www.kore3.com
Old 04-30-2010, 12:24 AM
Tobin
KORE3
theyre the C5 Z06 wheels. i have the tubs and drop spindles already what else would i need like what kinda spacers and where can i get em guys?? thanks in advance! JOE
Old 04-30-2010, 02:31 PM
6spdcamaro 6spdcamaro is offline
where can I get em guys??
http://www.Motorsport-tech.com
Ken
Old 05-04-2010, 02:58 PM
Drop spindles, eh? I'd suggest reading the sticky at the top of the Suspension Forum regarding drop spindles on rear steer F/X-body applications. With any backspacing over 4", you're likely to have interference issues between your tie-rod end and wheel hoop.
Tobin
KORE3
www.kore3.com
Old 05-28-2010, 02:11 AM
damn!! LOL yea i got the dse min tubs i need my car lowered i love the way it looks with drop spindles. i might even air bag it. thanks for all the feed back guys!
Old 05-28-2010, 05:58 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Place those drop spindles in your nearest trash can and put a stock spindle back on it. You can get the stance you want with a spring, either out of the box "lowering" spring, or a cut spring. Or use air bags with a stock sprindle.
What are the wheel specs? Width , backspace etc.
