Old 06-21-2010, 02:18 PM
JayR JayR is offline
Lateral-G Supporting Vendor
Default Rushforth 17" Super Spokes F/S!
SOLD!!!! Thanks Guys. We have another set that is completely brushed in the exact same specs if anyone's interested. I'll get them listed.
These were accidentally drilled with GM lug pattern instead of the 5x4.5 pattern they were supposed to get so they need to go!
Matte black centers with polished hoops in a nice basic fitment that will fit a lot of cars.
Retail for powdercoated 17s: $2250. We can ship these tomorrow for $1875 + shipping.
If you like these but they aren't quite right for your application, give us a call and we'll quote you for whatever you need.
17x8/ 4.75" BS/ 5x4.75 Bolt Pattern
17x10/ 5.5" BS/ 5x4.75 Bolt Pattern
Old 06-22-2010, 10:26 AM
rdalley rdalley is offline
Will the 17x10 fit the rear of a stock 64 Chevelle?
Old 06-22-2010, 10:47 AM
Not sure about 64s but it sounds like a squeeze. Measure from your mounting surface to the inner and outer obstructions. You'll need 12" overall to fit a 10 and be safe with the mounting surface almost dead center to run these 10s.
Old 06-22-2010, 09:37 PM
pragmatist pragmatist is offline
Default Maybe
Is it reasonable to replace the inside hoop on the front two wheels with one a 1/2" wider to make an 8.5" wide wheel with 5.25" back space? Just trying to make it happen. Thanks, S.
Old 06-24-2010, 08:55 AM
17x8.5 isn't a standard width so it would be a custom order that would bump the price pretty dramatically when an 8 will actually hold the same tire as an 8.5" wheel.
Old 06-24-2010, 06:23 PM
cp72ss cp72ss is offline
Default Hello
Was wondering if these would fit a 72 Chevelle? Has a little drop all the way around the car but nothing to drastic.
thanks
Old 06-24-2010, 09:41 PM
thanks
As you know, you have roomy wheelwells, so they'll fit just fine.
Old 07-08-2010, 11:29 AM
PatoRuzRS73's Avatar
PatoRuzRS73 PatoRuzRS73 is offline
They will fit a 73 camaro?
Old 07-08-2010, 03:51 PM
skatinjay27's Avatar
yes they are actually perfect widths and offsets for a 2nd gen
AJ
Old 07-08-2010, 04:11 PM
FadedSS FadedSS is offline
man i wish these were 18s! i would be all over them as theyre perfect for my 73 camaro
