Old 01-14-2005, 05:57 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Default Master Cylinder on the Malitude
Anyone know what MC that's on Malitude?
My LS7 69 Camaro
Old 01-17-2005, 06:30 AM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
Default C5 Vette MC
From what I saw of it, I'm confident that it is a '97-'02 C5 Vette mc. These run a 1" bore, can bolt to any later model short mc rod GM booster per traditional GM mc stud spacing and pushrod depth spec, weigh 2 lbs vs the cast iron 9 lb C3 Vette mc. Before you decide you want to run out and grab one, know that they are about $200 new through GM SPO (don't know that they are available new anywhere else YET), use the weird metric ISO bubble flare line connections, and the white plastic tanks discolor with use...
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 01-17-2005, 07:00 AM
XcYZ's Avatar
Cool, thanks for the info, Paul. The physical size caught my eye because running the downpipe past the MC is going to be interesting with the tall deck that I'm using.
My LS7 69 Camaro
