Old 07-20-2010, 10:45 AM
g356gear's Avatar
g356gear g356gear is offline
Default Mass Flo EFI.....good alternative?
Anyone know much about these systems?
www.massfloefi.com
System includes:
•Four barrel single plane Edelbrock Victor Jr intake manifold.
•Our own custom 1000 CFM 4 bbl throttle body. It features all aluminum and stainless steel construction, sealed ball bearings on the throttle shafts, and progressive linkage. Comes complete with idle control motor and throttle position sensor. This is absolutely the finest 4 bbl throttle body on the market!
•Jumbo fuel rails and mounts. Rails have 9/16" diameter bores providing excellent flow and dampening characteristics.
•Our custom compact high flow patented mass air meter. The air meter is concealed within the air cleaner of your choice to maintain the vintage look! Systems are also available with our patented Pro-M mass air meters for draw through or blow through application.
•Complete production quality wiring harness. This stand alone high quality harness allows easy installation of our EFI system into any vehicle without connecting to your existing harness. For ease of installation each harness connector is individually labeled.
•Production mass air sequential electronic fuel injection computer.
•Eight high quality fuel injectors, sized to your application. The injectors are sized to allow ample room for large increases in horsepower. These fuel injectors are held to much closer tolerance than typical production injectors.
•All needed sensors. Most of the sensors are mounted right on the injection system for a simple install. No crank sensor to complicate the process!
•High performance billet aluminum distributor complete with ignition module, rotor and cap. Our entire ignition system is contained within the distributor and ECM. Just install the distributor and plug it into the harness. No spark boxes needed. However, after market capacitive discharge ignition systems, boost retard systems, nitrous control systems, rev limiters and shift lights can all easily be added.
•High performance coil featuring faster rise time and increased spark duration for increased performance. This coil comes with heat sink and mounting bracket.
•Throttle body base gasket, throttle cable bracket, assorted hardware and fittings and detailed instructions for a simple turn key installation.
All of these components are absolutely the best quality available. Unlike the competition, we will never sell you something that is "good enough" just because it costs less to produce.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-20-2010, 05:34 PM
supremeefi supremeefi is offline
Default Mass Flo
1st question, how much cam do you have. Also, can't be true sequential if there is no cam sensor. You figure it out.
Check out my video where I talk about the very same system. Go to Featured Video on the bottom right.
http://www.accel-dfi.com/
Old 07-21-2010, 01:49 PM
Pdale Pdale is offline
If you have a duel sync distributor you can have sequential though right?
Old 07-21-2010, 02:01 PM
Yes that's exactly what they're for. And they are very convenient, one distributor, 2 pick ups. But obviously the ECM needs to be able to run in sequential as well. Some are but aren't adjustable.
Old 07-22-2010, 02:42 PM
71RS/SS396's Avatar
I have one on a truck project I'm doing, so far I like it, very responsive. I was told these are not that picky about cam selection due to it not using a map sensor, relies on maf and O2. It does seem to be very sensitive to fuel pressure though.
Old 07-22-2010, 03:27 PM
1Bad68Cat 1Bad68Cat is offline
Correct me if I'm wrong, but doesn't the system use mainly ford parts except for the mass air meter which is a modified 4th gen f-body. IIRC, the mass air ford stuff is sequential, but does require a chip if not stock. It will run, but it is not optimized. If you want laptop ability you can plug in a twEECr system to make adjustments on the fly.
Old 07-23-2010, 07:08 PM
Stick a big cam in it and let me know how it reacts. I have first hand knowledge that they don't like that at all.
Old 07-23-2010, 09:34 PM
Blown353 Blown353 is offline
While this doesn't apply to the Massflo system you can have full sequential injection without a cam sensor using only a reluctor wheel on the crank that has enough teeth to provide a high resolution crank signal to the ECU and the ECU has both the processing power and necessary software scheme to decode the crank signal. The ECU can watch the angular acceleration/deceleration of each tooth of the reluctor wheel during compression & firing and calculate/decode the firing order based on the individual tooth accel/decel and then run full sequential injection and also drive coil-per-plug without a cam sensor. I helped set up a Porsche 356 that's coil per plug and sequential injection with no cam sensor needed... and it works great. It's a Pantera 882 ECU by the way, I also have one sitting in the box waiting for my TT LS2 if I ever get it finished. My LS2 will still use a cam sensor although it isn't 100% needed with the 882; the cam sensor is still good for the ECU to do a firing order sanity check and "noise filtering" by comparing the cam signal to the decoded crank signal.
Back to Mass Flo, while I haven't used their specific setup I have messed with a couple of EEC-IV's using twEECer a while back in their native environments (5.0 mustangs.) While the EEC-IV and TFI distributor combo is getting a bit dated it can still run very well (both are readily available and easy to retrofit onto almost anything, probably why they chose it)-- but as was mentioned there are limitations when you get really "wild" with the engine combo. Mass Flo seems to really market to the "bolt on and go" crowd that wants EFI but really doesn't want to mess with it or learn the ins and outs.
My personal preference is for a more modern ECU and a crank reluctor wheel setup for its greater accuracy compared to a distributor trigger setup (no distributor gear backlash, no timing chain slack, etc to throw off injection & spark timing.) Lots more options to grow and change things in the future.
1969 Chevelle
Old 07-24-2010, 05:49 AM
Yes on the TFI distributor the #1 tab on the reluctor wheel is offset, that's how the EEC-IV knows where #1 is. And yes if you have an ECU that can read that then you can go sequential. But I believe the MassFlo system comes with a standard Mallory distributor. I'm pretty sure it fires in batch, not sequential.
But don't lose sight of the fact that while sequential is good, changeable/programmable sequential is better, sometimes much better. Watch the O2 correction as you change injector timing. It will change noticeably no question.
Watch my video on the Accel DFI website. The Mustang I refer to had a 246/249 @ .050 hyd roller in a 427W. They sent the ECU back 3 times, got 4 or 5 different chips, they lost count. Ran like ****. Chris at MassFlo tried to help but nothing worked.
Put the Accel Thruster on it. I put a base tune in it and it fired right up and idled fine. Runs great, guy drives it almost every day.
Also have a buddy who put 226/230 @ .050 cam in his 5.O, didn't run well either. When you said they have their limitations that may be an understatement.
Old 07-25-2010, 05:34 AM
71RS/SS396's Avatar
You sound like you work for Accel.
