Old 07-28-2010, 12:31 PM
g356gear's Avatar
g356gear g356gear is offline
Default Swap out front springs going to lighter motor?
Looking at switching to an all aluminum BBC from my all iron boat anchor currently in the car. I am running 2" Hotchkis drop springs currently. With the weight savings going to aluminum block, heads, intake, will I need to switch to a small block spring to maintain my front stance?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-28-2010, 01:12 PM
importkiller69ss's Avatar
importkiller69ss importkiller69ss is offline
Default springs
if i remember correctly thats what i was told. with the weight savings of an all aluminum bbc it is close to the weight of a sbc. may want to look into coil overs to adjust them
1969 ss 350,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......cusotm interior, 2 tone paint and front frame all in the works
Old 08-04-2010, 04:13 PM
Hotchkis Hotchkis is offline
senior member
If you are happy with the current stance of the car, switching from the Hotchkis BB spring, which is designed for a cast iron head, to the Hotchkis small block kit would be a wise move. Since switching the springs is not a terribly difficult thing, and since we generally have those parts in stock, as do our distributors, you could always do the engine swap and see what you think of the handling and stance.
