Old 09-27-2010, 07:36 PM
tekin tekin is offline
Default 700r4 tranny pan drain plug????
does any 700r4 tranny pans have a drain plug in them, i got a 2wd 700r4 thanks.
Or can I put anything else in there that would work, if so how
[email protected]
Old 09-28-2010, 05:30 AM
Aeroking Aeroking is offline
GM 4L65E pan fits and should have a drain plug.
1991 GMC Syclone
- Turbo oddfire V6, AWD, Belltech leafs and swaybars, Caltracs, Gen4 Fbody brakes, hydroboost, Tubular control arms, Afco Coilovers, Z box, 17x9s with 275/40/17s
Old 09-28-2010, 04:12 PM
Default tranny pan
well what you think is it ok to tap my existing pan or ???
Old 12-01-2010, 10:56 PM
JRouche JRouche is offline
Ya dont tap it, the metal is too thin. Just drill a hole and use a drain with seals, easy on the seals, doesnt take much pressure to have them seal or deform and NOT seal.
Oh, but then again you might have used the word tap as in to give it a tap, a drain tap
But yeah, for the sheetmetal pans just remove it and drill the hole (de-burr also) for the drain "tap" and its really a great inexpensive mod. I have unfortunately had to use mine a few times working out some issues in the lower part of the trans. JR
