Old 10-18-2010, 12:38 PM
brans72 brans72 is offline
Default reclaimer/vaccum for blasting cabinet
I was wondering what you guys recomm and use for reclaimer/vaccum on your blasting cabinets? On a tight budget but figured maybe someone could help me out here. Brandon
Old 10-18-2010, 01:48 PM
I used the upgraded version from TP Tools -- and also their reclaimer. Works like a charm.
Main thing with these "vacs" is that you want the blast cabinet to stay clear... otherwise you can't see what you're doing.
Personally - I vented mine to the outside for the exhaust side of the vac system -- when it was vented inside - I always felt "dirty" after using it for a bit. You don't want to get a nasty dose of silicosis... so inhaling the ultra fine dust these things make is a no no. Even though we use our home systems pretty lightly - I figure I don't want ANY... :>)
Old 10-19-2010, 01:25 PM
prostreet69cama's Avatar
prostreet69cama prostreet69cama is offline
I have a regular craftsman vacuum cleaner on mine. I ran a piece of PVC pipe to my attic and put the vacuum in the attic so it isn't as noisy. It does put dust up there and I have to clean the filter regularly. I works good when it is clean.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
