Old 10-24-2010, 09:22 PM
N2TRUX's Avatar
N2TRUX N2TRUX is offline
Default 12 bolt (Truck)- Narrowed- Eaton Posi- Richmond Gears (Houston TX)
I have a 12 bolt truck axle that has been professionally narrowed and built with all new premium parts. The housing is narrowed 3" each side which makes it 55" end to end, and 52 3/4" flange to flange. It was set up to run a 4 link on stock width 73-87 frame rails. It has a 4 series Eaton posi, with 4.10 Richmond gears.
Included are custom built Moser 30 spline axles running a 5x5" GM truck pattern, and Moser heavy duty bearings. Every part is brand new, mocked up with assembly grease but never used. The gears are set up and ready to run. All items are brand new, never used.
Complete package- 900.00
Old 11-07-2010, 07:33 PM
N2TRUX's Avatar
Wilwood Brakes- SOLD!
Ride Tech 4 Link- SOLD!
GM 12 Bolt-Reduced- 900.00
Old 11-08-2010, 04:58 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What's the width of the rear?
Bolt pattern?
Old 11-08-2010, 04:29 PM
N2TRUX's Avatar
The housing is 55" end to end, and 52 3/4" flange to flange. It is running a 5x5" GM truck pattern.
Old 11-11-2010, 08:18 AM
N2TRUX's Avatar
Price reduced.
This axle was set to run 18" M/T with stock rails like pictured below. Yes I know that a 9" pictured, just using the pic to show the set up.
