Old 11-06-2010, 08:19 AM
snappytravis's Avatar
Default 1969 Camaro wide trunk gap need advice?
Hello Camaro fans, I am currently restoring a 1969, I installed DSE mini tubs and new OER quarters, The qtrs seem to fit well along door edge and everywhere except the trunk gap, it is wide like 1/2 inch, anybody ran into this problem, starts out closest to back window good then gets wider about 1/3 of the way down towards rear panel any help would be apreciated Thanks
Old 11-06-2010, 10:08 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Yeah, everyone who's installed aftermarket quarters has.
Here's an example of may need to be done.
https://lateral-g.net/forums/show...t=26164&page=9
Old 11-06-2010, 04:46 PM
Default Holy Trunk Gap
Thanks for the reply, I cut the l.h. qtr last niight and brought it in, looks better, then will go to the r.h. side once I get the metal work done on the l.h. side, I was afraid that was the kind of reply that I would get, just nature of the beast, I do believe what did you use to grind it a roloc 36 grit or is there something that works better, looks like you have done that a time or two. thanks for the pics,
Old 11-08-2010, 05:17 AM
MarkM66's Avatar
Actually, that link isn't my work. But I have done it a time or two.
I like to take down the welds with a 3/16x3" wheel on a die grinder, just hitting the weld until I get it down to the sheet metal. Then finish up with a roloc sanding disc. Takes away less of the surrounding metal that way.
