Old 11-14-2010, 10:53 AM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default Bolt pattern and back space on a 69
Hey Guys-
There are a lot of threads out there with guides about what wheel/tire combo fits on what but there are a lot of differences depending where you look.
I have a 69 Camaro that will be lowered 2" front and back. Other than that, it is stock. I want to put 18's all around and I'm shopping for wheels today. What is the correct bolt pattern and suggested back space I should go with for front and back? I'm guessing the correct width should be 18X7 up front and 18X8.5 in the back, right? Or could I fit a wider width, too?
Thanks!
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 11-14-2010, 02:42 PM
John510's Avatar
John510 John510 is offline
Call Jon @ Driverzinc tomorrow. Most people here buy their wheels from him.
951-609-3483
Or you can look here for some fitments
http://www.pro-touring.com/tech/wheels/Wheel_Survey.htm
[SIGPIC][/SIGPIC]
Old 11-14-2010, 03:09 PM
sperger1 sperger1 is offline
Default 1968 Camaro with DSE Quadralink and 335???
I am building a 68 and have the dse deep tubs and Quadralink. Also, a Ford 9 from dse. I bought two 335 BF goodrich and I do not want to send them back. They look a little big. Can anyone help with the back spacing of my wheels and let me know what else we can do to make the 335 x 18 fit
Old 11-14-2010, 03:37 PM
JustinB's Avatar
JustinB JustinB is offline
bolt pattern is a 5x4.75. Up front you can run up to a 18x8 with 245/40/18 and ~5.0 BS. On the rear you can either go for a 18x9-18x10 depending on wheel choice and a 275/40/18 tire. BS will depend on the width you decide to go with. In general a 9 will have around a 5.25 and a 10 will be a 5.75. We have lots of packages we can put together for you. Feel free to shoot me a pm, email or call.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 11-14-2010, 10:10 PM
mrr1999's Avatar
Great info. Thanks, Justin. I'll PM you tomorrow.
70 Chevelle SS396
69 Mach I
Old 11-15-2010, 11:09 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Have you installed the DSE parts yet? Install the tubs allowing as much breathing room for the tires as possible and they should fit with 18x12s.
Old 11-15-2010, 04:41 PM
JustinB's Avatar
Safer to call me with measurements to make sure a 335 will fit without issue and dial in the BS.
Justin Butler
Old 11-15-2010, 04:42 PM
JustinB's Avatar
Glad I could help Mike!
Justin Butler
Old 11-16-2010, 08:15 PM
Originally Posted by JayR View Post
Have you installed the DSE parts yet? Install the tubs allowing as much breathing room fohe tires as possible and they should fit with 18x12s.
We have 14 5/8" min. with the dse installed.
Old 11-16-2010, 10:10 PM
JustinB's Avatar
Real close! The BFG KDW2 measures 13.5" wide on a 12" wheel. We like to see a minimum of .75" to the inside and 3/8" to the outside for clearance. You are right there. Backspace needs to be spot on! Feel free to call me and I can help you figure out the BS.
Justin Butler
