Old 11-14-2010, 03:54 PM
sperger1 sperger1 is offline
Default 1968 Camaro 335/30x18 with DSE stuff??
I have a 68 Camaro and just installed DSE tubs, quad and subframe connectors, but the 335 G force look like they will fit with the correct backspacing. Is there a thread out here that explains this?
Old 11-14-2010, 03:59 PM
6spdcamaro 6spdcamaro is offline
https://lateral-g.net/forums/show...hlight=dse+335
Each installation is a little different. In my opinion, its not worth it, because you can't fit a big enough tire in the front to justify it, unless it is for looks only.
Ken
Old 11-14-2010, 04:20 PM
Default 335 in a 68
We do 335s on 67 / 68s in our shop al the time, look at MotiV8r. But we know how to put the tubs in deep. Yours are installed relaxed. You need 14.5" to 14.75" to clear 335s on 12s. As Chris mentioned, 325s on a 11" rim are a nice fit but there are no 325 / 18s.
Frank Serafine
FREE PRO TOURING TECH & PROJECT PLANNING FOR FORUM MEMBERS
THERE ARE NO STUPID QUESTIONS, ONLY THOSE TOO STUPID TO ASK QUESTIONS!
FOUR ZERO SEVEN 832 1752 8am to 8pm eastern time
Pro Touring SuperStore
Everything You Need For Your Pro Touring Dream.
Prodigy Customs
Pro Touring Muscle Car Specialist
Frank said in this thread that if you put the tubs in deep, 335 will fit. What needs to be added and what backspacing?
Old 11-14-2010, 04:25 PM
Thanks Ken. I plan on using a dse front subframe too, but may wait and run the factory subframe. But can we get Baer brakes on the factory subframe and then change them to fit the DSE frame? I have the ford 9 from DSE with the Baer 6P brakes on the rear. I am just trying to get the tubs finished so we can get the wheels. I have purcahsed the 335s to see about fit, but it is tight. We have not finished welding the tubs yet, we also have to put the new rearend under the car and weld the final fitment.
And Yes, like most of us out here we like teh looks and the increase in traction. Probably mostly looks with most of us.
Old 11-14-2010, 09:53 PM
Musclerodz's Avatar
Only if you are running ATS spindles on the stock sub. DSE uses C6 uprights which is the same brake package for ATS spindles.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-16-2010, 07:05 AM
Thanks. I am torn if I want to rehab the stock subframe or just purchase DSE. I have Barr 6p on a DSE Ford 9. The stock subframe has discs already but not Barr
Old 11-16-2010, 08:28 AM
I have 14.625" with the DSE tubs in place. So looks l ike there is r oom for the 335.
Old 11-16-2010, 01:35 PM
Your welcome to call and discuss the virtures of moding your stock frame and going aftermarket.
Here are a couple 67 / 68s we have done with 335s
Frank Serafine
Old 11-16-2010, 04:41 PM
Bad94 Bad94 is offline
Frank, this might be a dumb question, but have you or do you know anyone with 335's on a 67/68 with leafs?
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 11-16-2010, 07:41 PM
Thanks Frank, I will try and call tomorrow. Want to get this thing on the road? Also, wanted to know more on the 540 horse LS3 you have
