Old 12-05-2010, 04:49 PM
Vortech404 Vortech404 is offline
Default 96Z rear into a 69?
I plan on doing the Detroit Speed or Speed Tech rear suspension set up on my 69 Camaro. Trying to stip as many parts off my built 96 Z/28.
Will my KTRE 12 bolt rear from my 96 fit into my 69?
John
Old 12-06-2010, 05:13 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Maybe, if you run a wheel with ton of positive offset, and it still may be to wide for that. And will also look like crap.
Or have it narrowed.
Old 12-06-2010, 07:27 PM
Thank's,
I figured I would have to get it narrowed.
Not too sure what the differance in length is. I guess I'll find out.
Thank's again
John
Old 12-10-2010, 09:51 AM
MarkM66's Avatar
Originally Posted by Vortech404 View Post
Thank's,
Thank's again
John
Buy the time you get it narrowed, and buy new axles, you might be better off selling it to someone who needs it, and putting that towards a rear to fit what you need.
Sure would be less hassle.
Old 12-25-2010, 10:48 AM
Does any body know what the length of a 4th gen F-body rear is compared to a 1st gen ?
Old 12-25-2010, 10:48 PM
rocketman's Avatar
stock is 4 th gen f body 64.72, most the aftermarket bolt in rear ends are 4 inches narrower, or at least i found the 12 bolt moser i bought was.
a stock 69 camaro is 60.00
