Old 01-11-2011, 10:12 PM
aany001's Avatar
aany001 aany001 is offline
Default Stock 69 camaro needs wheels
A buddy of mine has a stock 69 camaro SS and wants to put some new wheels on it.Its all stock with factory discs up front and drums out back.Anyone know the perfect sizes as in back spacing and offsets for a set of 18" or 17" wheels?? Wants the widest he can go but no modifications on front and rear.
Thanks in advance
Steve
Old 01-12-2011, 09:22 AM
8s up front with 4.75 to 5 BS, 9.5 on rear with 5.5 BS. 245 and 275s, keep the overall heigh of the fronts 26" or under, rear can go up to 27.5"
Frank Serafine
Old 01-12-2011, 11:53 AM
aany001's Avatar
Frank what would the offsets be?
Old 01-12-2011, 05:27 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Frank listed the back space in his post: BS = Back Spacing
Old 01-12-2011, 05:55 PM
Yup, the offsets that Frank listed are pretty much spot on. If you don't see wheels available in 9.5, run a 9" with a 5.25" Back Space, and the same 275/40/18
Old 01-12-2011, 08:09 PM
aany001's Avatar
I figured the back spacing but a wheel shop here locally asked what the offsets had to be? I always thought that's
What back spacing was offset. Thanks guys!
Old 01-12-2011, 09:39 PM
Us old school guys speak in backspace, not offset. But to answer your question
On the 8" wheel the offset of a 4.875 BS wheel is 9.5
On the 9.5" wheel the offset of a 5.5 BS wheel is 6.3
Frank Serafine
Old 01-13-2011, 08:08 PM
aany001's Avatar
Thanks guys for the info.
Old 01-14-2011, 03:39 PM
buickfunnycar.com's Avatar
Keep in mind you can also run 10" wide wheels in the rear generally w/o issues,that's what I run on my '69 Z/28 and it isn't tubbed....but this will be tight so accurate measurements of your buddy's car will need to be taken...measure twice,cut once.
I can also recommend Jon Henson @ www.driverzinc.com he's set up all my current cars as well as my daily drivers...
www.buickfunnycar.com
Old 01-18-2011, 07:03 PM
lutzy lutzy is offline
good info here!
