Old 01-13-2006, 05:46 PM
ArisESQ ArisESQ is offline
Default basic mini tub question....
i was just kinda looking through the DSE site and saw that they offered the wider camaro tubs alone, or with the mini tub package... i was wondering if anyone knew if there were any advantages to installing the tubs alone, without rellocating the springs, or if it was neccesary to move the springs to realy reap the benefit of the tubs. just curious. and thanks.
Old 01-13-2006, 07:25 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Yep, you'll have to move the leafs inward with offset shackles or go to a 3 or 4 link rear suspension to get any benefit from the Deep Tubs.
My LS7 69 Camaro
Old 01-13-2006, 08:33 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Ditto on what Scott said, you really need to go with the offset shackles to move the springs in and make use of the room the new tubs give you.
Kurt
www.autokraft.org
Old 02-16-2006, 07:08 AM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default minitub
I am in the process of doing the smaller minitub- that moves the inner fenderwell to the rear part of the frame - now the rear of the leaf spring is close to being in the way, doing a deeper tub would not benefit anything without moving the spring in . - that becomes a limiting factor- be ready when you move in the spring - you need a smaller-narrower fuel tank- and the costs go up more gotta love these cars!
Old 02-16-2006, 07:31 AM
Mean 69 Mean 69 is offline
You could put a three link in it and not have to modify the gas tank!
M
Old 02-16-2006, 08:53 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
M
Last I heard, to have the Lateral Dynamics 3 link and an exhaust that ended behind the rear axle, you had to notch gas tank for exhaust clearance. Is that no longer the case?
