Old 01-31-2011, 05:31 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Default Hole centering punch
Looking for a tool that will make a punch in the exact center of another hole. Something to make a pilot punch to transfer holes. Hole size in the 1/2" range.
Hope that makes sense, .
Old 01-31-2011, 05:56 PM
redss86 redss86 is offline
You are looking for a set of transfer punches like these:
http://www.amazon.com/TEKTON-7319-Tr.../dp/B000NPR3U2
Hope this helps.
Old 01-31-2011, 06:18 PM
MarkM66's Avatar
Old 01-31-2011, 06:57 PM
Yep -- Transfer punches - that's exactly what they're made to do. A couple "sets" will take you from teenie tiny to an 1"
I also use mine for scribes in certain cases (If the pattern is "thick enough" to have an edge). If you want to trace a pattern exactly 1/8" "LARGER" for trimming purposes... grab a 1/4" transfer punch and put the edge on your pattern and trace away!
Old 01-31-2011, 07:26 PM
Sieg's Avatar
Sieg Sieg is offline
Learn something everyday! Thanks guys
Old 02-01-2011, 07:55 AM
I'm with you Sieg.
