Old 02-01-2011, 03:44 PM
g356gear's Avatar
g356gear g356gear is offline
Default Speedtech Subframe??
I haven't seen many guys running the Speedtech sub-frame for the 69 Camaro. Mostly just the DSE units. Cost wise Speedtech has a big advantage and you can use different spindle and control arm set ups on their unit. Sub only weighs 125 lbs as well. Anyone have any feedback with the Speedtech unit as a comparison?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
