Old 02-04-2011, 09:45 AM
MAK567's Avatar
MAK567 MAK567 is offline
Default l92 heads
Will the l92 heads of a 6.2l work on a ls6 motor?any help would greatly be appreciated.
Old 02-04-2011, 10:34 AM
Rybar's Avatar
Rybar Rybar is offline
Pretty sure they will not work. L92's are square port and LS1/LS6's are cathedral ports. I think you require a 4.0" bore or larger for these heads.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 02-04-2011, 12:16 PM
ElkyZO6 ElkyZO6 is offline
L92 heads require a 4" bore or bigger, because of the intake vale being 2.16".
Old 02-04-2011, 12:21 PM
MAK567's Avatar
Thanks For The Replies
Old 02-05-2011, 06:38 PM
It's only the bore diameter that prevents them from working on any engine smaller than 6.0 liters. The heads also require a different intake but otherwise fit on all LSx engines. You don't even need different headers so long as you start with a 1-3/4" primary tube design header.
