Old 02-04-2011, 03:01 PM
HEEP's Avatar
HEEP HEEP is offline
Default Chevelle Frame Boxing ?
For all the guys who boxed their original frames, did you fill every hole in the frame? If you didn't, do you worry about water building up inside those cavities? Just thinking out loud.
Thanks,
HEEP
Old 02-04-2011, 07:43 PM
aktmracer's Avatar
aktmracer aktmracer is offline
When i did mine i did not fiil all of the holes. I left some of the larger one's to run lines and wires through. However after the car is completly mocked up, wired and plumbed i may fill what holes were not used. I also left holes in bottum of frame rail so it could drain. Before boxing i applied several coats of cold galvanizing paint then topped it with primer. I figured that would help protect it. Not extremely worried about water since car will not be driven in the rain and with the water hardness I have, not washed with water very often.
Jeriah
http://s812.photobucket.com/albums/z...67%20Chevelle/
1967 Chevelle LS1/4L60E
1980 FJ40 LT1/TH400 waiting to go in
Old 02-05-2011, 12:41 PM
lhkustoms's Avatar
lhkustoms lhkustoms is offline
I usually just box the rails and leave the smaller holes to let water drain. If your building a "show car" then you might fill all the holes. It's just a personal preference. If you just want to strengthen the frame you just need to box the main rails.
Luke Mau
L & H Kustoms
Old 02-10-2011, 04:24 AM
HEEP's Avatar
I'm mainly going for the stiffness. However, looks are always important. This will be like most here on this board, a driver that looks really good. Thanks, for the replies. I will be studying what holes can be left in and which ones should be filled.
HEEP
Old 02-10-2011, 08:02 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Don't fill the holes that bolt the body to the frame.
Old 02-10-2011, 08:22 AM
slenning's Avatar
slenning slenning is offline
Thats some darn good advice right there
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 02-10-2011, 08:24 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Hahahahahahaha!!! That's funny, I don't care who you are.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 02-14-2011, 03:05 AM
HEEP's Avatar
That is great advice. Too bad I didn't check this thread before yesterday.
Guess I better get my drill out.
Thanks guys fro the info.
HEEP
Old 02-26-2011, 01:22 PM
clu269's Avatar
clu269 clu269 is offline
Check out this link!
https://lateral-g.net/forums/showthread.php4?t=30717
Old 03-26-2011, 09:41 PM
GHOSTDANCER GHOSTDANCER is offline
http://www.artmorrison.com/gallery/m...2_itemId=15290
