Old 02-26-2011, 05:27 AM
aany001's Avatar
aany001 aany001 is offline
Default LS1 clearance issues
I am running into a clearance problem. I need to cut off 1 of the squares from the sides of the block.The LS1 has 3 on each side right at the bottom of the block and just above the oil pan.I need to remove the one on the drivers side closes to the front of the block.That 1"x1" x0.5" cube is stopping me from having room for my rack banjo fittings to fit in there.Do these squares have any purpose and can I trim down one of them.
Thanks in advance.
Steve
Old 02-26-2011, 08:26 AM
64pontiac 64pontiac is offline
I am pretty sure you would be ok to remove or clearance one. They look like extra casting to me, they are not tapped or anything, and are in between the side main cap bolts, so I don't think you should have an issue.
Just don't do what one of the teams did for the Holley LSfest challenge, NO HAMMERS!!!!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 02-26-2011, 06:46 PM
aany001's Avatar
thanks thats great news......LOL I saw that episode!!!!! WTF was that guy thinking
Old 02-27-2011, 10:53 AM
aany001's Avatar
anyone else know about these LS1 blocks?
Old 02-27-2011, 11:25 AM
camcojb camcojb is offline
I remember that the instructions for the APS twin turbo LS kits mentions that the rear one by the starter may have to be removed or reduced to clear their exhaust manifold. I do not think it is an issue to clearance them.
http://www.airpowersystems.com/gto/install/image062.jpg
Old 02-27-2011, 04:32 PM
catz's Avatar
catz catz is offline
Steve I did a unisteer install a while back had the same problem I just cut the small block off with a air saw and had no problem ,those blocks are just from the casting process just cut it Bob
Old 02-27-2011, 07:15 PM
aany001's Avatar
Sweet guys that awesome.I trimmed it back and now everything fits perfect.
Thanks again
Steve
