Old 03-24-2011, 03:53 PM
Pasquale Pasquale is offline
Default Please I need Ford 9" help!!!
I am making a high performance street 69 Camaro and I do not understand all the different options, such as ARB and True Trac, for a Ford 9". What would be the best for my situation if I'm running 1000 hp?
Old 03-24-2011, 04:13 PM
parsonsj parsonsj is offline
A Detroit Locker with 35 spline axles will hang on to that kind of power.
jp
John Parsons
Old 03-24-2011, 05:47 PM
jp
Is there another option that doesn't lock both wheels together, but can withstand high horsepower? Is this what most people use on high performance street cars?
Old 03-24-2011, 07:44 PM
OneCamaro OneCamaro is offline
This is the way to go.
http://www.moserengineering.com/diff...35-spline.html
Old 03-25-2011, 05:23 AM
kennyd's Avatar
kennyd kennyd is offline
A ARB is a air locker , used on off road rock crawlers . it will not take 1000 hp . I had them in my last crawler with a ls1 supercharged , broke the ARB .
I also agree a 35 spline with a detroit . A tru trac posi will work good But you probally will power thru it .
Old 03-25-2011, 11:01 AM
What kind of rear tires are you going to run? If you not going to put anything sticky out back you can run a Tru-Trac with 31 spline. But if you planning to put a Drag radial or stickier I agree with the boys above.
Jeff Allen
J2 Speed and Custom
Old 03-25-2011, 04:42 PM
Originally Posted by Pasquale
Is there another option that doesn't lock both wheels together?
Perhaps I'm misunderstanding your comment, but the Locker doesn't lock the wheels together (like a spool would). A Locker has an internal ratcheting mechanism to allow the wheels to rotate at different speeds during turns.
jp
John Parsons
Old 03-26-2011, 05:21 AM
out2kayak out2kayak is offline
Originally Posted by ezccole View Post
That's what I put into my car.
-- Joe
Old 03-26-2011, 04:21 PM
jp
Oh I did not know that. So when I make turns it will disengage and let the rear tires rotate individually? But then when I pick up speeds it will engage locking the wheels together?
Old 03-26-2011, 04:54 PM
Exactly. Some people find the engage/disengage a little harsh, because Lockers make some noise when that happens, especially at slow speeds like parking, making a U-turn, or backing out of a driveway. But in ordinary driving it isn't noticeable, and they work great for road racing and autoX.
And at 1000 hp, it's really the only game in town that will give you a true differential and the strength/durability you'll need.
jp
John Parsons
