Old 01-20-2006, 01:45 PM
almcbri's Avatar
almcbri almcbri is offline
Default Your Ideas: Using Parts from other vehicles
I was thinking this might be a good topic: I am a budget builder. I like to look for my own ways to use other parts from salvage yard vehicles to work on my camaro. I thought we could share ideas of different parts that work well with a variety of our PT style cars.
For Instance:
A Late model Corvette 6 speed Wiper motor looks identicle to the wiper motor that is sold by a aftermarket company. I have not tryed this, but I plan to buy the wiper motor with a wiring harness and build a adapter plate to mount into my firewall.
4th Gen Camaro seats work well in 67-69 camaros with a easy modification to the rear seat brackets. The front mounting points work with the stock holes.
Interior Insulation: I went to Lowe's and bought some insulation that is recommended for RV'S and auto's. 50 Sq. ft for $25.00
Custom Jute Board: (fits between the rear seat and trunk) I took a piece of the plastic board-(looks a lot like cardboard, but is a tough plastic) and wrapped my cheap interior insulation around it to make my own jute pad. I used some aerosol glue to tack the insulation
Late model corvette electric radiator fans and shroud is a pretty close fit on a 67-69 camaro radiator. 26"x18"x6" on the corvette shroud. Camaro radiator dimensions are a bit bigger.
A third gen. camaro rearend works well under my 68 camaro. Although I have been told the third gen. rears are not tough like the 1st and 2nd gens. My car is going to be street driven and mild so it should work well for me. I have a posi 3:23 from a 85 camaro w/ disc brakes and single piston calipers. Note: The rearend is .5 wider on each end, 1" wider than stock.
Custom Trunk Batter tray: I built mine out of .5" square tubing and 1/4" sheetmetal. I am having the tray sprayed with reflex truck bedliner.
4th gen camaro rearview mirrors: have a map light mounted in them for an extra light in the car. or a temp and directional mirror out of another late model vehicle.
Old 01-20-2006, 05:17 PM
Derek69SS's Avatar
Mostly Chevelle related:
Ford Windstar electric fans fit well on Chevelles.
Caprice 9C1's and Jeep Grand Cherokee's have quick-ratio steering boxes that fit chevelles.
2nd Gen F-body sway-bars fit Chevelles.
Camaro/Chevelle/Nova drum spindles can be made into disc spindles in about 20 minutes each with a grinder.
Old 01-21-2006, 06:58 AM
AAW's Avatar
AAW AAW is offline
Supporting Vendor
Default Does this count?
I once took the floormats out of my husband's car and put them in my car...all by myself. Does that count?
~Theresa~
Old 01-21-2006, 08:18 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
~Theresa~
LOL!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-21-2006, 08:23 AM
almcbri's Avatar
whatever works I guess.
All by yourself? impressive
Old 01-21-2006, 08:34 AM
XcYZ's Avatar
XcYZ XcYZ is offline
~Theresa~
Does that count? I guess it would depend on how long before he came and took them back.
My LS7 69 Camaro
Old 01-21-2006, 10:45 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
~Theresa~
Were they COPO/Nickey/Motion floor mats?
Jim
Old 01-21-2006, 12:13 PM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
In my Buick Regal I am using a dash from a 59 Impala...............fender port holes for heating/AC from a 53 buick..............badges are door panel badges from a 1961 buick special......................trunk shock set up is from a 79 monte carlo..................................seats are from a mid 80's nissan......................steering column is from a caprice classic.....................air cleaner is the "star wars" looking one from a 69 buick GS....................rear speaker center grill is from a 65 riviera.......................many more items will be from earlier buicks...........
www.hotrodderjournal.com
Old 01-21-2006, 08:53 PM
Keith's Avatar
Keith Keith is offline
Well, we bought ours brand new but you should be able to get chrysler crossfire side mirrors at the junkyard now. Dont forget the switch that's in the console. Wiring is straight forward and fits the angle of my chevelle's door like a glove. They are power/heated and flip-up manually for tight garage space. I just had to drill new holes to accomodate them.
There's nothing more common than unsucessful men with talent
GENESIS CHEVELLE
Old 01-21-2006, 09:19 PM
ohcbird's Avatar
ohcbird ohcbird is offline
I have a 4th gen rearview mirror in my 68.
