Old 04-09-2011, 02:25 PM
fast400 fast400 is offline
Default QA1 ride height difference
I just installed a QA1 coilover setup in my 69 Firebird. I ensured that both sides were exactly 5 threads up from the bottom of the shock as a starting point.
The problem is that the R side is almost 1/2" lower than the L side when I measure.
What could cause this??
Before I adjust to correct the height difference...will it negatively affect things if the right is up 8 threads from the bottom and the L only 5 threads??
Old 04-09-2011, 02:33 PM
Blake Foster's Avatar
was it correct prior to installing the QA1's?
make sure the spring is seated correctly up inside the top pocket on the sub frame. that will do it.
there is a tapered pocket for the spring up in there.
Blake Foster
www.speedtechperformance.com
Old 04-09-2011, 11:40 PM
It was perfect before. The springs are correctly seated too...that was my first thought
Old 04-11-2011, 01:51 PM
67Rally's Avatar
67Rally 67Rally is offline
Forgive my ignorance (especially on a first post), but isn't one of the benefits of the adjustable coilovers that you can even out small differences in ride height from one side to the next?
Old 04-13-2011, 08:27 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Switch the springs from side to side to see if the problem is the spring or the car. It is possible that an inexpensive spring could vary in height and/or load capacity by that much.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 01-27-2012, 11:00 PM
sanman's Avatar
sanman sanman is offline
Bret,
I see your quality responses on several boards, You the MAN. I am sure I speak for many. Its great to see someone who is not only running a big business but also taking the time to help those with questions. Keep it up you have proven yourself to me to a genuine dude!!!
