Old 04-14-2011, 04:06 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Roller Rockers
I'm making a list of items that I still need to finish my car. One thing I was debating about getting was a set of roller rockers. How much would they help on a street car. It will be a L92 or LS3 (depending on if I keep the VVT or not) and should be 550 or so hp. Thanks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 04-14-2011, 05:29 PM
Rybar's Avatar
Rybar Rybar is offline
Mike, I don't know how necessary they are on LS motors. I had my stockers rebuilt by Harland Sharp with different bearings that are more durable than the needle bearings, and its cheaper than full roller rockers.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-14-2011, 06:50 PM
Mike --
I wouldn't change 'em......
Unless you're planning on really hammering the thing and high revs etc. Spend you're money on something that will count for more.
Old 04-14-2011, 08:26 PM
ma73z's Avatar
ma73z ma73z is offline
I went with the comp cams trunion kit on mine, it's like $130 bucks and easy to do.
Old 04-14-2011, 09:12 PM
scherp69's Avatar
Thanks guys. Another item I can cross off the list of don't needs.
Mike
New Gen Splitters
LS3 and TKO600
Old 04-14-2011, 09:33 PM
Ron in SoCal's Avatar
I'm going against the grain here - anyone who digs high revvin', hammer the throttle motoring can benefit from a set of rollers on a 11.4:1 compression motor. You'll only get limited HP bump, but they're so smooth and they rev so nice I would not build a motor any different. My personal opinion is they protect your valve train from unnecessary damage.
Flame away guys...
Ron in SoCal
69 Camaro in progress
Old 04-14-2011, 11:26 PM
scherp69's Avatar
Flame away guys...
What about a stock L92 though? No 11:4 compression there.
Mike
New Gen Splitters
LS3 and TKO600
Old 04-15-2011, 01:04 AM
You're right, I believe it's 10.7 but you're still going to cam it and (I'm sure) step on it once in a while, right?
Ron in SoCal
Old 04-15-2011, 01:17 PM
scherp69's Avatar
Of course I'm going to step on in once in a while. What I'm wondering though, are the gains worth the $500 at this stage in my build. Or is it one of those nice to have items that when I upgrade my heads as a winter project, I do the rockers at the same time. I'm trying to make my purchases count from now on so I can get my list of 'things I still need" shorter.
Mike
New Gen Splitters
LS3 and TKO600
Old 04-15-2011, 01:27 PM
Mike --
Make your list SHORTER.... rollers are "nice" and are fun to say you have... but certainly aren't required "now".... and this is a super easy down the line upgrade item.
It's what makes some of these builds take so long! If you don't have super deep pockets - buying all the 'frills' and making the build super complicated - is just holding up your "fun". Get that bad boy on the road... and leave the easy upgrades for later.
Having said this - I always advise when building a motor - and you want to use aluminum heads - don't wait to get those later -- because the motor is a total of the parts and they need to be there from the get go. But roller rockers aren't going to affect a stock motors performance at this point in time.
It's like wheels -- they're super important to know what you're going to run - offset - backspace - width etc... so they need to be "in the mix" when you're building -- the TIRES --- not so much. Buy "get 'er done" tires (the proper size etc) and save up for the killer $500 each versions when you're ready.
