Closed Thread
Old 05-09-2011, 11:59 PM
jocko124 jocko124 is offline
Default Best place to buy a T-56 Magnum
I'm finally going to pull the trigger on a T-56 Magnum for my 66 Cutlass (455 Olds Engine). Where is the best place to purchase one?
Old 05-10-2011, 12:20 AM
Tom.A's Avatar
Tom.A Tom.A is offline
I would use Hurst Driveline unless you can find a discount code for Summit Racing
Tom
Old 05-10-2011, 12:23 AM
canrc canrc is offline
x2 on Hurst Drivelines
Great service got mine exactly when promised.
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 05-10-2011, 12:32 AM
That's a great idea. Now I just gotta figure out where 2 get a Summit discount code.
Old 05-10-2011, 08:14 AM
wmhjr wmhjr is offline
Often the discount codes will not work for items such as the T56 Magnum. I'd check around to see what the delta will be in total cost once it's all done so you make sure you don't end up paying the least amount for the tranny but end up getting nickle and dimed to death along with any support issues. Personally I'd stick with Hurst Driveline but that's just me.
Old 05-10-2011, 09:07 AM
fesler's Avatar
fesler fesler is offline
Call us up we have pretty good deals on them. Ask for Rob 480-748-2000
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 05-10-2011, 10:21 AM
I agree Bill. I just wanted to make sure there isn't a less expensive option I'm overlooking before pulling the trigger.
Thanks Chris. I'll give Rob a call.
Old 05-10-2011, 10:25 AM
The WidowMaker's Avatar
got mine from summit with the 10% code. i had the tko kit so i didnt need all the small parts and i didnt want a kit clutch anyways.
"The WidowMaker"
Old 05-10-2011, 10:53 AM
I know Hurst extends the warranty on the T-56 Mag by a year. In a street application, is that worth anything? I really have not heard of any issues with this trans---at least not that I've seen anywhere on here or pro-touring.com.
Closed Thread
