Old 05-23-2011, 03:28 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Is anyone using a Keisler R/T 56?
Hello:
Is anyone using a Keisler R/T 56, "Dogbox" Transmission?
If so, how you you like it?
What did you put it in?
What do you think about it?
I'm looking forward to your post.
Thanks,
Ty O'Neal
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 05-24-2011, 08:30 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I'm curious how long they last...
I was interested in one briefly, but decided it probably wasn't the right part for my intended application. Try searching on a few of the Corvette forums. I seem to remember a sponsor pushing the transmission kits, and I think few members might have posted feedback.
Matt
Old 05-31-2011, 09:01 AM
captainofiron's Avatar
captainofiron captainofiron is offline
I had initially wanted the keisler kit, as for a while they were the only visible source of retrofit kits for the t--56
but now that I have looked around, there are many more sources, that are much cheaper, all you have to do is some research and legwork
Old 06-04-2011, 06:12 PM
andrewb70's Avatar
Please point me to just one other dog-ring retrofit kit for the T56, there aren't "more sources."
I had a Liberty modified T56. It was outfitted with dog rings in gears 1-4. With respect to the driving experience it would be similar to the Keisler kit, although the Keisler kit will definitely handle more power, because my Liberty trans used stock gears. Here are my impressions from day one....
http://www.ls1tech.com/forums/manual...ertys-t56.html
Andrew
Old 06-04-2011, 06:41 PM
Andrew
oops, didnt even see the dogbox part of the OP
Anyways, other t56 sources
Hurst Driveline
http://www.hurst-drivelines.com/inde...d=47&Itemid=56
Weir Hot Rods
http://www.weirhotrodproducts.com/index.html
D&D performance
http://www.ddperformance.com/
American Powertrain
http://www.americanpowertrain.com/
Old 06-04-2011, 06:58 PM
chicane's Avatar
chicane chicane is offline
Ya forgot one...
http://www.rsgear.com
Old 06-04-2011, 07:01 PM
andrewb70's Avatar
And here is yet another:
http://www.gforcetransmissions.com/tran_gt-56.asp
But none of them are dog-ring boxes, which is what the OP was asking about.
Andrew
Old 06-04-2011, 07:09 PM
chicane's Avatar
The only T-56 'dog ring' transmissions that are marketed here in the USA (and for the most part, available)... are the boxes from Rockland Standard and Keisler.
The Aussie's have a few as well... but they are only rated at around 500hp max... and run about $1k for a single rebuild, which happens more than anyone would want to run in a street chassis.
Old 07-31-2011, 03:46 AM
tyoneal's Avatar
Originally Posted by chicane View Post
Ya forgot one...
This still has Synchronizers where as the Road and Track doesn't.
Here is a specific link to the product. I probably should have posted this to begin with.
I hope this helps Identifying the transmission easier.
http://www.keislerauto.com/recent-ne...k-6-speed.html
Thanks,
Ty O'Neal
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 08-07-2011, 05:09 PM
Croaker's Avatar
Croaker Croaker is offline
I'd also be interested in some feedback on the R/T-56. Haven't really heard much about it since it was released, especially now that Keisler is marketing their RS transmissions so heavily.
