Old 05-29-2011, 08:46 AM
Ron in SoCal's Avatar
Default Electric Water Pump?
Question for the Pros...is an electric water pump, Meziere etc., worth the expense...$500 or so? This would be for a dual purpose street/track car so I want it to work equally well doing both. I'm spending a boatload on HP right now and read you gain 10hp due to less parasitic loss.
What do you guys think?
Ron in SoCal
69 Camaro in progress
Old 05-29-2011, 08:51 AM
Leave it GM....10hp isn't worth the potential trouble.
Old 05-29-2011, 09:02 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Keep it simple! You will get your car done quicker..
Cris Gonzalez
Old 05-29-2011, 12:27 PM
Thanks guys. I was kinda thinking the same thing...
Ron in SoCal
Old 05-29-2011, 01:40 PM
There's a very good reason you can go to a car show - and look at 1000's of cars - and maybe 1 will be running an electric pump... and that will be the trailer queen '41 Willys... that's never been anywhere - ever....
Old 05-31-2011, 06:57 AM
wmhjr wmhjr is offline
Totally agree.
The mechanical water pump is a pretty hardy design. They don't fail very often, and in the grand scheme of things if you really need that extra little power, design it in somewhere else.
If you switch to electric, you not only need to worry about electrical issues not only causing overheat issues due to electric fan failures, but then ALSO that you'll not even be recirculating water.
The other thing you'll need to figure out is accessory brackets. They pretty much all assume you're running an OEM type water pump, so no matter what you do you're fabricating all your brackets.
