Old 06-22-2011, 07:31 AM
alistair's Avatar
alistair alistair is offline
Default 18" wheel fitment for '69 Camaro
Hi guys
I've done a little looking into this and I know the answer really is "depends" rather than anything concrete but I'd like to sap up as much of your excellent experience as I can for our project '69 Camaro
The car is currently dead stock and was restored a couple years ago.
We want to run about 2" lower (not with blocks) and we want to run 18" diameter rims. I'd love to think we can get 10x18 under the stock rear tubs with stock located springs in place. I somehow suspect we can't though.
We will be running disc brakes all round and I am aware sometimes that changes the requirement on backspace etc. a little.
Your thoughts and comments are most welcome guys.
Old 06-22-2011, 08:01 AM
Sieg's Avatar
Sieg Sieg is offline
I am running 245/40/18 and 275/40/18 on 18x8/18x9.5. The approximate fender lip to ground measurements are 24.5f and 25.2r. Fronts rub when turning in parking lots a little. I've pushed it pretty hard on a twisty road with no contact issues. Rear tail pipe routing may be an issue, my 2,5" pipes needed to be flatted aproximately .75". Pan head bolts and a little metal massaging should neutralize it. Stock A-arms, lowered coils and leafs, 1" blocks in leafs. Pinion angle went downward 2*.
Old 06-22-2011, 08:16 AM
alistair's Avatar
thanks, that's really helpful information. What backspace have your wheels?
Old 06-22-2011, 09:42 AM
Sieg's Avatar
Sorry about that. 5"f and 5.5"r
Old 06-22-2011, 10:13 AM
alistair's Avatar
thanks, big help. We're getting a plan together now!
Old 06-22-2011, 11:33 AM
Rybar's Avatar
Rybar Rybar is offline
You can run 18x10's w/ 275-40-18's on the back if you roll your lips on the 1/4's and you don't have your ride height super low. I did and had no rubbing issues with the suspension setup right. This was with de-arched dropped leafs and QA1 shocks.
The wheels were 18x10 with 5.75" BS, stock width rear and Baer disc brake kit.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-22-2011, 11:40 AM
alistair's Avatar
thanks for that. rolling the arches is an option
Old 06-22-2011, 02:55 PM
Rybar's Avatar
Also, search username musclecarjohn, he's running 18x10's on his stock tubbed '69
1969 CAMARO RS
Old 06-22-2011, 03:11 PM
JustinB's Avatar
JustinB JustinB is offline
we have set up tons of 69's with 18x10. Feel free to take look at our website galleries for wheel ideas. www.driverzinc.com
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 06-22-2011, 03:34 PM
buickfunnycar.com's Avatar
Wink My ears were burning...
Jon Henson has set up all my cars (even my DD's) and I'm sure he and Justin can do the same for you.
Stock tubs...I even run spacers to pull them out the edge,lol
car's available by the way...
www.buickfunnycar.com
