70 GTO with 2002 z-28 brakes f/r, 1 inch vette, master cylender...
Page 1 of 2
1
2
07-24-2011, 10:01 AM
Ummgawa
70 GTO with 2002 z-28 brakes f/r, 1 inch vette, master cylinder...
Standard booster.
What proportioning valve (the disk drum is on it) should I run, or should I run a line pressure valve on the rear line, a proportioning valve...
OR WHAT!? Help is needed.
Jim
11:43 AM
Ummgawa
Find all posts by Ummgawa
2
07-24-2011, 04:32 PM
Ummgawa
Oh c'mon, somebody else has got to be wondering the same as I. Lil help gents!
Jim
Ummgawa
3
07-24-2011, 05:23 PM
dhutton
Originally Posted by
Ummgawa
I have a similar setup and run a Wilwood adjustable prop valve. I don't think a residual pressure valve is needed with discs, only drums.
Don
09:21 AM
dhutton
Find all posts by dhutton
4
07-24-2011, 05:31 PM
bmiller
dhutton
I have a similar setup and run a Wilwood adjutsable prop valve. I don't think a residual pressure valve is needed with discs, only drums.
Don
x2
I also changed the rear line from 1/4 to 3/16 but I don't know if thats a must for everyones apps
bmiller
Find all posts by bmiller
5
07-24-2011, 06:15 PM
Ummgawa
Don,
do you run the wilwood valve instead of the factory prop valve?
Thanks a million for the response.
Jim
Ummgawa
6
07-25-2011, 04:20 AM
dhutton
Ummgawa
Don,
Yes, just the Wilwood valve, no factory prop valve.
dhutton
7
07-25-2011, 06:53 AM
Ummgawa
Don,
Thanks for the help, what is the F/R bias on the prop valve, 50/50, 60/40?
Jim
Ummgawa
8
07-25-2011, 09:20 AM
dhutton
Ummgawa
Don,
It's adjustable:
http://www.amazon.com/Wilwood-Adjust.../dp/B003LT619Q
Don
dhutton
9
07-26-2011, 07:02 AM
Ummgawa
Thanks Don, I just ordered one.
Jim
Ummgawa
10
07-26-2011, 08:21 AM
Payton King
Hey Jim!
Have not heard from you in a while.
They are all correct...of course. Dial in the bias once you get the car going. make sure you do a panic stop to verify the rear will not lock up before the front.
Payton King
Find all posts by Payton King
Page 1 of 2
1
2
Linear Mode
Switch to Threaded Mode
03:05 PM
