Closed Thread
Old 07-26-2011, 08:42 PM
NOPANTS68 NOPANTS68 is offline
Default '68 Nova LS1/T56
I'm putting the Nova up for sale as I just don't seem to drive it much. I'm starting a new business and have no time for the car right now. It's a fun street car that always attracts a crowd at shows. It's turn key reliable and ready to race or just take out for ice cream. The car can be converted back to PT with a wheel change and a shock adjustment. I've had 17x11s on it with 315s and think the car can swallow a 335 if you were careful with backspacing. The 6 speed conversion and new 9 inch have less than 500 miles on them. The trans has 50K on it and has been a great upgrade, making the car more versitile. Looking for $26K. Here's the specs:
1968 Nova
Body
-Finished in Lemans Blue PPG base/clear with semi gloss black Baldwin Motion style stripes bordered in vintage white
-started with completely rust free body with all original sheetmetal (aftermarket steel 4 inch cowl hood)
-New door and hood hinges
-All panels gapped perfectly- doors and trunk shut with minimal effort
-Newer vinyl top with new stainless trim
-Detroit Speed minitub kit installed- trunk finished with factory style look
-S&M race cars 8 point cage with camera mount- custom floor plates
-New mirrors, emblems, door locks, etc
-Paint is in excellent shape with some minor flaws- far better than driver quality- car is shown and does win paint awards
-Entire floor covered in Fatmat sound deadener
Chassis
-QA1 adjustable front billet coilovers
-Addco 1.125 inch sway bar with urethane mounts
-SSBC front brake kit- slotted rotors and billet calipers- Wilwood billet master cyl.
-Unisteer manual rack and pinion steering system with polished stainless link kit
-New urethane bushings, new ball joints, wheel bearings etc
-Competition Engineering subframe connectors
-Inboarded Eaton Detroit leaf springs using Comp engineering rear mounts
-Custom rear shock mounts with Comp Engineering adjustable shocks/ custom lower shock perches for optimal shock angles
-Custom traction bars with adjustable links
-Custom ordered Currie 9 inch rear diff. with 5 inch narrower track to optimize DSE kit (gives more wheel options and a far wider rear lip) – spine braced, filler cap, drain, vent
-new Strange Pro-G nodular third member
-new Detroit Locker, Richmond 4.33 gears
-new 35 spline Moser axles, new bearings and seals
-Centerline Telstar billet wheels- 15 x 7 (new 205/60/15) and 15 x 10 (Mickey Thompson 325/50/15 Drag radial) The car can run an 11 inch wheel and a 315+ tire. The custom narrow housing allows for a 6 inch deep rear lip.
-2003 LS1 (all aluminum)
-TEA ported heads
-Autokraft oil pan
-Edelbrock motor mounts and coated headers
-Thunder Racing Trex 2.0 cam (242/248 .608/.612 110 LSA)- new LS2 timing chain-matched valve springs, locks, Ti retainers etc
-Thunder Racing new ported and polished LS6 oil pump
-Comp Cams Heavy duty pushrods
-6.0L heavy duty Coil packs and Taylor plug wires
-Edelbrock victor intake manifold and custom Holley HP 750 carb built by Competition Carburetion of Nevada
-MSD 6010 timing controller with easy to use laptop software, custom billet bulkhead harness plate
-2.5 inch exhaust with 3.5 inch electric cutouts, Bullet mufflers, X pipe, and over the axle terminating under the bumper tailpipes
-Meziere billet electric water pump with in-car adjustable speed controller
-Holley blue fuel pump- (-8 delivery line, -8 to carb, Holley reg. with gauge, -8 return line,20 gallon aluminum cell with AN beathers and sump)
-Custom ordered Griffin radiator with 1.5” tubes (-20 AN water lines, 1600 cfm fan) car runs 175-190 on even the hottest days in traffic
-T-56 trans with Hurst billet shifter
-new Monster level 3 clutch
-new Billet steel flywheel
-new ARP hardware
-new Custom tubular trans crossmember with drop out center
-new Quicktime SFI scattershield
-new brand new steel driveshaft by Driveline service with all 1350 Spicer joints
-Custom billet capped center console/ Lokar boot/ Hurst pistol knob with line lock
Interior
-New door panels, hardware, and dash pad
-Custom built gauge panel with billet gauge surround, billet control panels, Autometer gauges and tach
-Corbeau race seats, G force 5 point harnesses, custom rear bulkhead panels and package tray
-New headliner and mirror
-Painless wiring harness
-Lecarra steering wheel
A couple things to fix- gas gauge and volt meter went on the fritz last week. Could be a ground. One of the cutouts has decided to no longer open. All will be fixed before it leaves my garage. The weakest areas are the carpet and a couple tiny spots in the paint that you wouldn't notice unless I pointed them out.
walk around video when it had the auto in it: https://www.youtube.com/watch?v=w0dL_VBNqEI
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 07-27-2011, 05:27 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Looks like a great car in one of my favorite colors. Great asking price.
GLWS.
Old 07-29-2011, 07:24 PM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Wow, that is a gorgeous car! GLWS
Jason
www.fquick.com/ZZ3ElCamino
Old 07-30-2011, 08:53 AM
Thanks for the kind words dudes. A bunch of guys have asked for interior pics and other outside photos.
1956 Chevy 210
Newcastle , CA
Old 08-09-2011, 01:19 AM
Chevy Kid Chevy Kid is offline
GLWS sale, Dave. The buyer will not be disappointed.
Tim
Old 08-09-2011, 10:09 AM
6D9 6D9 is offline
Bummed to see ya sell it....
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 08-09-2011, 10:59 AM
Flash68's Avatar
Flash68 Flash68 is offline
Very cool car. Best of luck.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-09-2011, 11:14 AM
Thanks guys for the kind words. It may be gone this weekend if the deal goes through. I'm really going to miss it.
1956 Chevy 210
Newcastle , CA
Old 08-09-2011, 03:29 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
you should show it in PT form looks good
Old 08-09-2011, 09:31 PM
ok lol. Here it is with VWW V48s with 11 inch rears and 315s. It has the 1.125 in. sway bar and the QA1s on kill mode. Handled really well.
1956 Chevy 210
Newcastle , CA
Closed Thread
