Old 07-27-2011, 11:51 AM
dcdman67 dcdman67 is offline
Default 1967 Camaro w/o mini-tubs...want tucked look
I want to achieve that tucked look on my 1967 camaro. I have a TCI front subframe/suspension and the rear 4 link. Does anyone have an idea of tire/wheel size that I can run to get that look. Want to get the widest tire I can on it without rubbing.
Car is still in the build stage, so rolling fender lips are a possibility.
Thanks in advance...
Dan
Old 08-02-2011, 10:08 AM
Fikse Wheels's Avatar
Fikse Wheels Fikse Wheels is offline
Dan
If you're going for a tucked look, I'd stick with a 9.5" rear with a 275, maybe a 285. This will likely still require that you roll the fenders a bit for them to tuck in, but they'll fit great. Here's a shot of a '67 with 18 X 10.0"s in the rear - They wouldn't be able to tuck but, with another 1/2" taken off the outside, they would.
FIKSE WHEELS
Old 08-02-2011, 10:12 AM
On a 67-68 you want to stick toa 9-9.5" wheel at the widest, with a 275/40/18 or there about. Backspacing is key, but we can dial you in so that its as far tucked in as possible, so you have enough room to lower your ride.
Old 11-15-2011, 07:34 PM
randy randy is offline
well mine is mini tubbed with the dse quadralink. Im pretty sure i can get the rear to tuck but what about the front?
Old 11-16-2011, 05:31 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
8" width 5.25" bs.
