Old 07-29-2011, 06:09 PM
Ivan Vella Ivan Vella is offline
Default width of a 10 bolt diff in a 69 camaro
Hello,
I was wondering if anyone knows what the width is of a 10 bolt diff in a 69 Camaro?
I'm looking at purchasing a Moser 9inch with 35 spline axles and a Wavetrac and I will have to narrow it 1 inch each side to fit the new Rushforths under the guards.
This will clear by 3/4 of an inch on the outers once they are rolled and the inner guards by 1/2 an inch. There should be enough clearance around the bottom of the shocks and leaf mounts etc.
I'm not really sure how to measure the diff, does anyone have the factory spec's?
Anyhelp would be greatly appreciated.
Ivan
Old 07-30-2011, 05:35 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Moser will know. Ask them when you order it.
Old 08-28-2011, 08:35 AM
zmaniac's Avatar
zmaniac zmaniac is offline
60" Wheel to Wheel
