Old 07-30-2011, 07:59 AM
orangevert's Avatar
orangevert orangevert is offline
Default 12bolt rear end width?
I'm having my 12 bolt rear shortened to54". What are you running for back spacing on your wheels running 18- 12
It's a 69 camaro
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 08-08-2011, 05:21 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
IMO, You would be much better off buying your wheels first and then narrow the rear to fit the wheels. 54" sounds too narrow, my rear is 57". My wheels are 18x12 with 5.75"bs if I remember correctly.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 08-09-2011, 08:30 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Yeah definitely buy wheels first... then take care of the rear end to make a perfect fit.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 08-12-2011, 05:04 PM
TheJDMan's Avatar
Here is what my rear end looks like installed. This is a Moser with floating hubs and as previously stated it measuers 57" wheel face to wheel face.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 08-13-2011, 04:02 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
What's your wheel backspacing?
Any pics from the side?
