Old 08-14-2011, 04:04 AM
Adam68 Adam68 is offline
Default Air cleaner option for QF 1250 dominator carb
Hi All
I am looking for a air cleaner set up for the following set up
STD deck big block
Super victor milled down 1/4 inch to make it the same height as a Victor Jnr
MSD dizzy
It needs to fit under a 68 Camaro 2 inch cowl bonnet with the standard underside recess
I am going to call Universal Spinners tomorrow but there 2inch drop base set up but it is 16 inch and won't fit in the bonnet underside recess
I have thought about using a small 16 inch filter with their set up and them back to back with the top and bottom cut out a 14inch KN X top filter with the smallest 14 inch filter.
Does anybody know the approximate height from the bottom of the manifold to the underside of a 2 inch or another option that will work?
Old 08-25-2011, 09:02 AM
bearcat bearcat is offline
I have a universal spinners bottom plate for a 4500 series carb. Assuming you want to switch to that size element, I can sell it to you for a good price. I barely used it and switched to a 4150. Oh, It fit on victor intake, dominator carb, lowered suspension under a 2 inch hood.....barely, but it fit. Let me know if you want it. 50 bucks and I'll send it your way.
Old 08-25-2011, 09:31 AM
JustinB's Avatar
JustinB JustinB is offline
If lowered suspension had anything to do with making a motor fit under the hood, I could fit two of my big blocks on top of each other under my stock cowl hood! lol.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 08-25-2011, 09:45 AM
haha....well obvious I was stating that it worked with a lowered bushings in the frame and dropped spindles.....
Old 08-25-2011, 11:26 AM
JustinB's Avatar
I know what you were getting at. Just had to bust your chops!
Justin Butler
