Old 08-20-2011, 05:04 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Default AWD transmission in a 72 Nova
A buddy of mine was given a transmission (AWD) from a 2006 Escalade. He's wondering if he can change it from an all wheel drive transmission by removing the transfer case and changing the output shaft and make it work in his 72 Nova. Anyone know if this can be done.
Jose
Old 08-20-2011, 05:43 PM
70rs's Avatar
70rs 70rs is offline
I saw the thread title and was hoping for a interesting new AWD Nova project.
Eric
Old 08-20-2011, 06:36 PM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
I was right there with you on that
Jeff Weidner
1970 nova in pieces
Old 08-20-2011, 06:57 PM
JUSTANOVA JUSTANOVA is offline
yes, you should be able to just change the ouput shaft and put the 2wd tail housing on and be good to go, then you just need a crossmember for the
4l60e and shorten the driveshaft to match.
I do think the trans has to be completely dissassembled to change the output shaft.....would be a good time to rebuild it.
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
Old 08-21-2011, 09:23 AM
Ketzer's Avatar
Ketzer Ketzer is offline
x3!
Old 08-21-2011, 11:58 AM
CRCRFT78's Avatar
Haha yeah I knew the title would pique the curiosity of some and possibly get me my answer. Maybe I should just tell my buddy to make his Nova AWD instead.
Jose
Old 08-21-2011, 10:40 PM
projectile's Avatar
projectile projectile is offline
It can be done. Shaft is held in by a snap ring. Have to disassemble trans to get to snap ring. Might want to consider a rebuild at that point, or at least seals and gaskets for sure.
Ray
