Old 09-06-2011, 07:28 PM
orangevert's Avatar
orangevert orangevert is offline
Default DSE Coil Over Kit
Can anyone post up some pictures of there DSE coil over kit install. Im having a little issue of the shock hitting the shock tower, It's barely touching, but I dont want to grind on anything.
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 09-07-2011, 11:56 AM
Jay Hilliard's Avatar
post a pic. Do you have the suspension loaded? not on jack stands etc.
Jay
Old 09-07-2011, 01:25 PM
orangevert's Avatar
Thanks Jay,
I do not have the suspension loaded yet, The sub frame is out of the car. motor is off of subframe. I will try and get it mounted up and set back on ground, Wheels don't come in until mid next week
Thanks again Jay
Kirk
Old 09-08-2011, 09:39 AM
Bad94 Bad94 is offline
You have the new style coil overs right? THe afco/DSE ones?
If so you have to trim the mounts. I had too.
Kyle and i talked about that when i did mine, i was one of the 1st to have the new coil over for the stock sub frame.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 09-08-2011, 04:23 PM
orangevert's Avatar
Thanks for the reply Bad94, I have the DSE coil overs, Just got them a month ago, I have a call into DSE, Do you have any picture of your shock towers?
Thanks Kirk
Kirk
Old 09-08-2011, 05:50 PM
Van B's Avatar
Van B Van B is offline
I know I have the original style, but may I ask what is different about the new ones?
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 09-08-2011, 09:04 PM
Denvervet's Avatar
Denvervet Denvervet is offline
I trimmed mine a bit too. Ultimately didn't have to since I needed to turn the collars down a bit since it was setting too low. Don't be afraid
68 camaro, 572, tko
