Old 09-13-2011, 08:47 AM
64pontiac 64pontiac is offline
Default LS9 Intercooler plumbing routing/help
Ok need some help from the guru's, ie Mark or anyone with LS9 experience!!!
I have a CTS-V reservoir for the intercooler system..... I am guessing it should be kept up high at the intercooler core level?
Also, where have you been sending the overflow....back to the rad overflow?
One last question....... I noticed on the Red Devil it looks like you may have epoxied in AN fittings to the stock plastic reservoir... is this what you did? If so, did you use the stock bosch pump with plastic nipples too, or did you have it converted to AN or use a different pump?
thanks alot guys! Anything helps.....
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
Old 09-16-2011, 12:41 PM
Stielow's Avatar
Stielow Stielow is offline
I used a CTS-V reservoir as the fill point for the system. The overflow I send to the ground but I epoxied the cap to make it non-venting. The trick to the whole deal is use a Snap-On evacuation and fill attachment to fill the system.
This deal allows you to pull a vacuum on the system then fill it. It works great. I also made the CTS-V cap the high point on my system top allow me to top it off.
I'm running all stock type rubber hoses for the system. I did cap off one end of the CTS-V reservoir just for packaging reasons.
Mark
Old 09-16-2011, 08:54 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
There you have it...pointers from the best.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-19-2011, 11:44 AM
Thanks Mark!!! I have a bunch of close up pics of your cars (sorry I took pictures for reference at Sema the last couple years)
and this is what I figured you did! You will like the way we have done ours..... very similar, but with a bit of a different look.
Thanks again!
Tyler
HPI Customs
Manitoba, Canada
www.hpicustoms.com
